Re: The Avengers - Loki's Spear Build WIP
So sorry for the delay in updates! I unexpectedly got accepted into graduate school rather last minute (a clerical error, discovered I was in three days before start of term) and have spent the last month quite busy dealing with paperwork, classes, research and teaching duties, so I have had no time to focus on web-presence. I had to prioritize my time between grad school, propmaking, hygiene and posting to the web, so the web had to seriously go. Been at work on this the whole time though, and it's getting so close to molding I can feel the twinge in my arm from mixing silicone already!
On to the pics:
Got the basic staff butt done, I'll be molding it like his for the scepter version, then adding the two extra plates to it for the spear version
I was terrible about taking photos for building up the main spear blade, but styrene photographs badly anyways, so NBD. I built up the contours for the blade in styrene layers, then did the blade bevels in apoxie sculpt. This is the blade after preliminary priming and sanding.
For the underblade base, I used a combination of sintra and styrene and sanded in the blade bevels by hand (lawd do I need a belt sander).
The gem will be rigged up with an embedded LED to light up, so I'm tucking he battery pack into the cavity of the "backplate" area. here it is roughly cut out. This will also be the access for one of the assembly screws. All of this will be hidden under a plate secured with magnets.
The gem will be cast in tinted clear resin with micropearl pigments to scatter the light from the LED. Here we have the sculpt for the gem in plastalina. I went with the texture from the screen used prop, however, in the film the gem is always CGed over. I used an old scrap terry cloth towel for the texture.
Here are the pieces thus far laid out together. The white piece is just some leftover resin I ran in the gem mold to finish cleaning out clay residue.
Here is the base piece for the gem, sculpted in apoxie sculpt. The wire for the LED will feed through this and into the backplate assembly.
Speaking of backplate, I also had to go in with some more spoxie and fill in the back end to create a snug slot for the handle to slip into.
Here's the underblade assembly primed and sanded smooth
Closer, I really love this bit for some reason.
And the blades all primed and sanded down.
More to come!
