That looks great Sandman! :thumbsup
It's a real beauty when it's all light up.
Woooohoo! That looks super cool. Well done!
That looks amazing! And it is only your first prop! Wow!
Eleisonn
First off, welcome. Secondly, fantastic work! This turned out amazing!
That is really impressive, the workmanship is flawless.
Wow, very impressive. How does the shadow look against the wall?
Wow! What are you going to do for your second prop?
Thank you!:eek This is your first prop?!! Excellent! :thumbsup
I have not added up the total cost. All the acrylic used is drop from jobs we have done at work. Same thing with the aluminum.How much did this cost you in parts?
No, I don't think I'll be selling them. Out of curiosity what would something like this go for? You guys are the pros, I just started.That looks so awesome outside. Could you imagine having these as flood lights around your house!? Some changes might need to be made to the construction if it was going to be an outdoor item. But I wouldn't want to risk someone running off with my bat signal.
Awesome work, are you thinking about selling them on the forum down the road?
That's an excellent Bat signal.
What did you use for the light tube or main barrel? Apologies if i missed it in the thread.
Excellent work, this came out really nice!!!
Thank you.I'm not much of a Batman fan, but this is massively cool.![]()
Two things. What is the amount of lumens you've been using? A projector uses anywhere from 1300 to 4500. Also, have you done a multiple LED setup where you can focus, say, 5 sets of 10 LEDS(small flashlight) at the center of the bat logo? Without it being focused you'd have more excess light shining on the spot where the shadow should be.
I'm not a light guy, but it's just a couple of things that came to mind for me.
First: A lumen is a measurement of the total amount of VISIBLE light produced by a light source. 1 Lumen = about the power of a single candle.
Second: I did a little research because I'm really interested in seeing this work for you. I found that in other shadow casting items (like this: Lumen Oil Candle Shadow Projectors) the light source is pretty close to the figure you want to cast as a shadow. Using the Flash light, or a flood light is a good idea, but I think you'd have better luck using something you can focus the beam with. Buying a couple of these (FordEx Group 300lm Adjustable Flashlight) is a relatively inexpensive way to do that. The light source for the size of the bat logo should prolly be about 6-8 inches away. If that. With you being able to focus the beam, it could further back. In theory.
If you have a flood light you could just use that. You'd need to figure out a way to focus it, however, so you could set it back further so it didn't mess with the look of the signal.
Whether you try any of this or not, it's a cool design.Good job.
