KevVader
Originally posted by Star Wars Man@Mar 20 2006, 09:10 PM
update?
[snapback]1209795[/snapback]
....patience, young Jedi.....
update?
Originally posted by SL3844@Mar 4 2006, 09:41 AM
Lookin good, Kev.
I enjoyed my AP as long as I had it... had to get rid of the armor recently. :cry
Here's a little tip in case of Dremel mishap - should you slip and accidentally score the plastic, cut some ABS strips from scrap pieces from the kit and dissolve them in a drop if acetone. When ABS has turned into a white goo, apply on damaged area, let dry, sand & polish. I got a deep scratch on my faceplate (didn't even see it happening), just below the right eye. Saw this tip somewhere, tried it - works like a charm.
[snapback]1198598[/snapback]
Originally posted by troopermaster@Mar 25 2006, 07:54 AM
Also,drawing a faint line where you are going to trim helps alot
-Paul.
[snapback]1213008[/snapback]
Originally posted by clutch@Apr 8 2006, 11:02 PM
You're kickin' arse Kev. How'd you get the shoulder straps cut so straight.? Keep the ab/crotch together. The originals were all one piece.
[snapback]1222823[/snapback]
Originally posted by KevVader@Apr 10 2006, 09:29 PM
Well....I tried painting the frown today.....Hmmm...not sure but the shade of gray that I had used (Testors 1138)..... looks too dark to me. I think they used Humbrol on the originals?
I think I messed up the line of the mouth as well....gonna repaint it....
Anyhow...thoughts?....paint #'s?
[snapback]1223816[/snapback]
Well, iirc, only the RotJ version had paint on the edges of the frown as well as on the teeth, but those were done in black, not grey.Originally posted by The Dark Side+Apr 10 2006, 10:50 PM--><div class='quotetop'>QUOTE(The Dark Side @ Apr 10 2006, 10:50 PM)</div><!--QuoteBegin-KevVaderI think you need a little less on the teeth area, just paint the actual indivdual teeth. Trooper Pics@Apr 10 2006, 09:29 PM
Joe
[snapback]1223823[/snapback][/b]
Originally posted by yakcam@Apr 10 2006, 05:55 PM
Looking great Kev :thumbsup
I've avoided using a dremel on mine, I suck at using a dremel, I'm prone to slipping. I just used a set of tin snips and the score and snap method.
I've seen both Testors 1138 and the Humbrol AD 5 grey and they seem very close, so close I don't really think it matters, IMO.
Cheers,
Kraig
[snapback]1223905[/snapback]
