Boneman
Member
Hello RPF,
I need some advice and suggestions on what electro-mechanical device(s) I could use to have the door on a box (worn like a back pack), auto open and close by the push of a button. This is for a Tanjiro / Demon Slayer cosplay build I'm helping my 16yr daughter with. Here are some examples of the box for context. We've already built a study 14"W x 24"H wood box using cedar 1x1 as an internal frame and then skinned with 1/8" Mahogany plywood - very light yet strong.
The Concept:
We thought it would be really cool to have the ability to push a button (hidden) and have the door be able to open (not all the way) and then be able to close. We would have some LED lighting and a plushy "Nezuko" doll inside.
I was thinking along the lines of a linear actuator like this, hooked up to a small battery pack and remote system. I would hinge the linear actuator at the bottom, hinge side of the door, so if was a shorter stroke one, it would pop the door open 45 degrees. Would want the door opening and closing to be somewhat slow - definitely not super fast.
Obviously weight is a concern as we are wanting the box to be as light as possible as it will be worn for hours at Comic Con conventions. An actuator or servo that could run off a USB Battery Bank (3-5vdc) would be optimal.
Anyone with any thoughts or input on how we could simply achieve this action would be much appreciated!! Thanks!
The Concept:
