Boba Fett Flight Suit
ActionProps
I am making a boba Fett costume for a Halloween party on the 28th and all I need is the flight suit, or some other option that looks good enough, so if anyone has any tips it would be great. Here are some pictures of my progress so far (These pictures are a bit old and since then I’ve finished the blaster, codpiece, ammo pouches and girth belt)
If you are not going for movie accurate you can get cheap overalls from amazon or places like ACE hardware, that could work for your needs...
I found these coveralls on amazon and I’m going to modify them by adding pouches, pockets and sleeves and making the fit look more accurate https://uploads.tapatalk-cdn.com/20171021/9993d3fe50d24e2d24ded23aaeb262ee.jpg
Those look great! Cut the long sleeves off of one and see them to the inside of the short sleeved one. The suit can be baggy as you put it on because it tightens up when the belt is added.
Sent from my XT1097 using Tapatalk
That’s my plan. But thanks PropReplicator2, you’ve been a big help!
this is actually a outstanding job! love how you used cardboard. i remember in 7th grade i did this as well, it didnt come out 5% as good as yours! really impressive with these materials you choose. good for you! :thumbsup
Thanks, I tried to make it “semi”-accurate without spending too much money. It’s a mix between the ESB and ROTJ with the gauntlets being ROTJ and the Jetpack and blaster being ESB
