Lflank
I want to introduce you to a personal friend of mine. This is the M41A1 pulse rifle. Ten millimeter with over-and-under thirty millimeter pump-action grenade launcher:
And here is how I made it.
Airsoft Thompson submachine gun:
Airsoft Spas 12 Franchi shotgun (the clear body was the only one Amazon had):
Airsoft collapsible stock:
First step: removing the Tommy gun stock and foregrip:
Next, removing the Spas cage and pump handle:
Test-fitting the basic concept:
Using a Dremel to cut the pump handle to the right length (new rim is made from foamie):
Removing the shotgun guts and cutting off the back section of the barrels:
All the required Airsoft parts:
Fitting the barrel section into the back end of the Spas cage, which now becomes the front end of the grenade launcher:
The grenade launcher parts glued into place, and a barrel cover made from foamie:
Test-fitting the shrouds. The shrouds were cut from plastic "for sale" signs. Because the Airsoft guns are shorter than the real ones, the shroud templates had to be stretched in the vertical direction, about two inches, to compensate:
Cutting foamie sheets to fill the inside of the hollow handle:
The foamie pieces glued into position:
The shrouds glued into place:
Using joint compound to smooth out the seams in the shrouds:
The finished pulse rifle, painted and with greeblies:
Thanks to Stealth for inspiring me to get off my behind and do this project after months of putting it off.
