laurend
Member
So for NYCC I'm working on my first replica costume and decided to go with one of Captain America's USO girls from TFA (the original costume from the beginning of his 'press tour' so no sequins and 6 smaller stars instead of 2).
So far I have the red-trimmed petticoat finished-lined with a white lining fabric to make sitting more comfortable. I may add another layer to this, depending on how it sits under the skirt, I'd rather have it a little less for now and be able to add then have to pull it apart later.
I've also done the base of the bodice, based on a slight modification to the Simplicity 3784 pattern (lowered/widened the neck line, made the back slightly lower, also had to adjust for my body type)
Now the parts I'm seeking some guidance with are the skirt, the belts and the lapels. I'm making the lapels out of the same blue satin as the bodice and I know a few people have made this costume before (I requested access to the Facebook group but haven't been let in yet so I figured here would be a good place to find someone). So basically, I'm wondering how the lapels were attached?
So far my thoughts are that I may have to pull apart the seam at the neckline and work them in to there-definitely should have thought out farther ahead of time. Or possibly finding some way to attach them as-is, an extra overhang of fabric that I can sew in to the inside of the neckline and then fold over and maybe tack the backs of the lapels down with some iron-on hem tape. So I guess basically I'm wondering how anyone has done this before? And if your process worked/didn't work well. ANy advice would definitely be welcome though.
And for the skirt, I'm thinking they look like 6" panels (plus seam allowance) of the red and white, pressed in half and then stitched alternating, sewn in to the waist still folded and then hemmed in one go. Can anyone confirm or correct this?
And I'm a little unsure the dimensions of the belt though, if anyone has that info I'd definitely be grateful. Otherwise I might have to just do some trial and error.
Thanks in advance for any input!
