OK, I'm getting started on my version of the new Carol Danvers suit and thought I'd go ahead and throw it into the mix.
So, let's just jump right in. Like many MCU costumes, Captain Marvel is constructed in several pieces. The main part of the upper body is a vest with a clever closure system in the back. This vest fits over an undershirt that contains the sleeves. Once I had the measurements and proportions confirmed with the client, I set out to begin the pattern. Here are just a few of the many reference images I used for the torso.
Fortunately, I happened to have a form that was the same size as the client and I was able to use it to create a base by wrapping the form in plastic wrap and then masking tape. Once I had the form covered as much as I needed, I began mapping out the various seam lines needed to create the basic shapes.
Note that, at this point, I'm only working out the lines needed to make the shapes for the mockup. Once the mock up is fitted and adjusted, then I'll add in all the little detail seams - like the rounded seams on the sides and all the back details.
The tape base was removed from the form, cut apart and transferred to Swedish tracing paper.
I then cut out all the pieces and built a mock up of the vest out of some leftover cordura I had in the studio.
Again, I'm just wanting to test for fit and the right shapes and proportion. Once that's confirmed, I'll be adding in all the stretch insets, refining the lines and cutting in all the details.
Next will be to create the patterns and mock ups for the shirt/sleeves and pants. Then, all the mock ups will go to the client for a fitting.
