What are you guys casting that needs mold release?
I'm not putting you down but in all my years I have never needed it.
If you use it religiously it will extend the life of a silicone mold as it prevents the permeation of the resin into the surface of the silicone that dries out the mold...
And I have found you can double the remaining pulls out of dying mold if you use release...
As for it messing with the surface, that depends on the release being used, using some of the fine misted spray paraffin and/or polymer based releases results in nil surface issues... A heavy or bush on coat, yeah it messes with things...
Three reasons I use it on a master before molding...
1. To simply aid when removing the master from the mold, a good Carnauba wax job or spray release really aides in removal...
2. It can also be used as a surface sealer for porous materials like plaster or wood that I have found silicone will sometimes seep into and bind...
3. To provide a barrier from possible cure inhibition, and surprisingly there are several things that will play havoc with curing, especially with the platinum cure silicones... I almost always use it on a piece I'm not familiar with and isn't mine... God knows what might be on the surface or what chemical substance might be present... Especially on an organic or natural piece that you don't know the composition of... Clear coating or painting isn't always an option, but you might be able to get by with a misting of paraffin...
