Wow the gelcoat you guys have over there must suck if you have to do 3 coats.
If you can afford it, the Smooth On Epoxy stuff is really good and the gelcoat (the red one) is very popular.
The gel coat in the States is a bit more sensitive to moisture than the UK stuff... I have used both. But the Gel Coats work fine over here.
All comes down to experience and technique.
That is why I have sprayed my gel coats... I can do an entire body.. Standing up...all at once... Gel application time about 30 minutes for the whole mould.
Not one pin hole or bubble due to the spray application.
No need to even think about gravity due to the spray application.
It is a nice technique to have.
Greg... It does come down to where You live at times...
Looking for a distributor can be advantageous though...
5 gallons gel comes to around $120... And goes a LONG way.
Epoxy works, but is really expensive.
For a mould that will not run more than 15-20 times... Epoxy can be a waste of money IMO.
Look up companies like Rev-Chem... Or AP Products to name a couple...
Greg, You mentioned Monster Clay... Which has a high wax content. By that, you have to be mindful of the clays sensitivity to heat.
Are You planning on shimming? Or clay wall?
