Gaffi stick made from a Fijian made replica Totokia. Tom Spina sourced these around 1998 and sold them on here. It is intricately carved and looks very cool. The round part of club is 5"-6" in diameter. Whatever native wood was used was so hard to drill that it completely dulled two spade bits. The blade is not accurate, though made from Tom's directions. The blades are too thin, but still look okay. They are glued on with Goop glue (fake welds) and are strong. I've bumped them and they don't pop off. The pipe is galvanized steel, so you could remove the galvanization fairly easily to make it look like rusty steel if you like. The very tip (maybe 1/16") had been damaged during shipping when I initially got it (you can see it in the second picture if you zoom). It was filled and I painted it, which doesn't match 100%, but you can see what was added and remove if you want (it's acrylic). The tube was also glued in with Goop, but after 27 years you might be able to twist it out and remove it. It's in there about 6" so it might be easier to strip it and weld on accurate blades. The spike tip is wood and is just press fit in there so it can be removed. Overall it measures around 54" long. Because of the size I'm only selling to U.S. members, sorry. Send me a message if you have any questions.
I will calculate shipping if someone buys it as I need to custom make a box for it. I'm leaving this on here for two weeks and then it goes to ebay.
