bpwmd
hey guys i know alot of people use hot glue to glue the thicker foam sheets edge on edge (or a butt joint for any wood workers here) But what does one use for for the thin 2mm foam sheets (the kind in the scrapbooking section of joanns) in making the same joint???
also any tips on fiberglassing (for strength as this will be a casting buck) and getting a nice perfect finish on the surface for said casting
this is what im trying to make for anyones refrence the internal support will be cardboard or such but the outside will be foam
http://www.thedentedhelmet.com/f23/...et-templates-build-45938/?highlight=rafalfett
