? On barrel, it’s not too thin?Looking good so far. Keep going !
Really don’t want to blue this thing , what would b the next alternative?That's turning out well!
Check out my build thread for a few more tips on blueing for a more controlled blueing on certain parts.Really don’t want to blue this thing , what would b the next alternative?
What about my barrel, it’s not too thin what paint in bottom.Blueing isn't hard, I do it pretty often. Get some Birchwood Casey Super Blue, some applicators, and rubber gloves. Oh and you'll need some fine 0000 steel wool. I would give it a rub down with the steel wool before you do it, it seems to take better. You'll probably need to do 3 applications. The process is: apply blueing solution, rinse with cold water, dry, buff with steel wool, wash, dry, repeat.
Alternatively you could paint it. Actually the lower should be painted, and the upper should be blued to be accurate.
Oh so that’s uWare could I get aluminum tube for the barrel?The thickness of the barrel doesn't matter.
Use flat black spray paint and after it dries rub it down with a paper towel to give a tiny bit of sheen.
I made a series of videos on my build.
What’s the measurements on the barrel 1 inch?Yes, the bull barrel should be a bit larger in diameter, and there are chamfers where it steps up higher than the frame. And the underside is flat, to allow the upper to slide back when the action cycles.View attachment 1033745
The one I made , is actually steel ware can I get an aluminum one ?I think 7/8 I can't remember. I got the ID and OD of the barrel and bought aluminum tube. Used a metal file and a hacksaw to make it! I would recommend buying one just for the ease of fitting it to the barrel shoulder, real pain!
I like high heat grill paint by rustoleum
Why not just get a Field Marshal bull barrel and flash hider?
