Kilryth
Who has had experience with both PVC and ABS materials for Prop making? I'll tell you what I know, in hopes that someone can tell me what I don't know.
They're both vacuum-formable, both can be flexible and durable, and both are lightweight. ABS is generally treated with a UV protectant to keep it from degrading in UV rays, but the protectant causes it to yellow in time with too much sun exposure. Obviously not a problem, if you paint it.
My questions are: Given the same thickness plastic, which one is more durable? Which one is more flexible? Which one is more likely to chip, dent, crack, or break when dropped on concrete? Has anyone done stress testing with them?
I'd like this post to be about general prop building materials and their specifications, rather than focusing on their applications.
This link was also helpful in comparing their properties: http://www.diffen.com/difference/ABS_vs_PVC
ABS is more impact-resistant than PVC.
Edit: Through some additional research on PVC roofing, I've found:
PVC becomes soft/flexible from the increased use of Plasticizers. Plasticizers tend to evaporate with exposure to heat, rain, and UV rays. This leaves the PVC less flexible, more brittle, and more prone to damage from impact. In essence, PVC is a brittle resin that is filled with liquid plasticizers, which improves flexibility and durability.
