Range Trooper Analysis Thread
tubachris85x
I'll be producing a mirroring thread on our Blizzard Force forums, but wanted to get something going here too.
We're learning a little bit as we go along, but the Art of Solo book has quotes from Glyn Dillon about the developments.
Key things:
- Duster/parka is made of Sheepskin, inspired by Russian military garb. Is it all one piece or is the kama portion a separate add-on?
- Actors were much taller, said to be over 6' tall (this falls inline with the descriptions that they were suppose to be a more "hardcore" snowtrooper, according to Glyn)
- Boots had a steam-release practical effect, which worked in tandem with lights as actors too a step. The boots were at least 105 pieces, required an instruction manual to be build by the prop builders and the 2 canisters on the rear contained the steam/water (?) not too clear there.
- Helmet. Not much to add here other than that earlier "reference" depicted the visor as having a center-recessed detail, however, latest reference clearly show it is just a plain, gold/solar bronze colored visor.
What we lack currently:
- Reference. Right now we've only got decent front-body reference, we need better backside reference.
- Gloves- I believe that these are off the shelf gloves, possibly either heavy gardening or possibly even beekeeping gloves. I say this as looking at the reference it appears that the gloves have an extended cuff. Appears to be a softer/lighter leather/lamb or sheepskin type glove. upper palm (just below where the fingers start) is an added strip of material for reinforcement. There's an additional strip running through the center of this as well.
- Pants. Doesn't appear to be anything significant, however, below the thigh plates, it looks like there may be a pre-existing pocket, which makes me wonder if it's off the shelf as well.
-Fur- It may be low hanging fruit, especially since how we know the costume builders for Game of Thrones operated by literally taking rugs from Ikea, cutting them, dying them and throwing them onto the actors. This appears honestly no different. Ikea continues to sell rugs that appear nearly identical in terms of fur length/appearance. It's my idea, at least for replication, to acquire enough rug material to use for the collar, and kama liner (to include the inner parka sleeve cuffs.
-Chest: Clearly inspired by the original snowtrooper chest, lower side portions appear to secure through a slot in the parka (along with that hose detail). I surmise that the shoulder straps are the same as seen for the mud-trooper (or not) as they're not seen.
- Back plate: Currently only best reference is the toys. It's clearly a shore/tank-trooper style back, but sticking through the back of the parka.
- Abdominal/Cod: The main ab plate (not the belt "buckle") appears to be one piece, with the cod hanging off the bottom. This is all sandwiched by the belt and "buckle" with a very similar snowtrooper ab disc, and pouches. Cod does not extend over, unlike the original snowtrooper cod.
I welcome further discussion!
About frikkin' time. :D Been waiting for someone to start a thread like this. I haven't had time. Let's see...
Looks one-piece, to me. The bits disappearing behind the armhole cutouts on the chest armor line up well with the skirt emerging below it. Probably the same gap all the way up. Note also the straps that go down between the legs to keep it from flapping in high winds.
Any idea how much over? I'm only 6'1"...
Yikes...
The whole thing looks, to me, to be heavily based on the Tank Driver helmet lower (the flare matches) with the Shoretrooper/AT-ACT Driver upper (the angled "outer armor" pieces to the sides of the visor), just with the latter part continued up to become a full outer armor "cap", where the Shoretrooper's gets cut off for the forehead shield and the "cutaway" look around the sides and back. And a new faceplate that's kind of an inspiration-mashup between the Shoretrooper and Death Trooper. I have no doubt some are already sculpting/modeling these, but those are the hallmarks I noted to be mindful of.
What I've noticed, too. How accurate do we consider the Black Series figures? About the only other one I've seen is from the Topps card set:
Might be pants. How likely d'you think it's a very-light gray-to-off-white jumpsuit? Given how much is hidden, doing it as a two-piece would probably work, if one wanted to go that route, but I have a feeling something might be occasionally glimpsed above the chest plate. It doesn't seem to be a re-use of any established pattern. It might be a mod of the Rogue One U-Wing Pilot jumpsuit. That had a pouch pocket on the right thigh of those, that could have been replaced with the patch pocket and angled flap,, and a zippered pocket on the left, which may be absent or completely hidden by the left thigh plate. Those jumpsuits were custom made, but apparently heavily inspired by actual flight suits, as they carried over zippers and pockets that are pointless, unused, and/or hidden on the Rogue One pilots. So this might be the same sort of thing. It is highly unlikely to be an actual off-the-rack item, though, as they seem to live by the credo "Try to pull this one off, cosplayers."
How 'bout the blaster?
Long barrelled E-11, scope mounted at the front, ribbed folding stock shoulder piece/foregrip, stock extension off the endcap...
These guys are so great. Is there any canonical image of them without the magnetic boots?
At this moment, no. Per the visual guide, the rangetroopers on Vandor are specifically assigned to protecting the conveyex line, so I don't think we will ever see a variant without these mangetic boots
Do you already have the other angles of the blaster rifle, and the magnetic boots on their own? Or shall I scan them and post them when I have a chance?
