Rey/Luke/Anakin's lightsaber box (Maz Kanata's castle)
oswaldthegreat
Jr Member
Hi,
I decided yesterday that I want to make a display box to hold Rey/Luke/Anakin's lightsaber, like the one it is found in in Maz Kanata's castle. Does anyone have any reference images of the box and the contents? I heard somewhere that the box is the same box as the lightsaber is in when Obi-Wan gives it to Luke in ANH, but I can't find any clear pictures of the box then as it is mostly out of shot. I'm going to see the film again (for the third time) on Sunday so I'm going to try and memorise what it looks like then, but it would be helpful if there are any pictures of it.
Thank you!
*EDIT* My initial search foo failed me, but you should check here for more input:
http://www.therpf.com/showthread.php?t=252889&highlight=maz's+box
Sadly, I haven't been able to find much reference for the box either. I'm sure some shots will appear sooner than later.
The best I've found is from the visual dictionary:
I found another picture in the visual dictionary, albeit rather small.
Thanks very much for those pics, I should probably get my hands on the visual dictionary, might be helpful. Yikes, I didn't realise quite how weathered the box was, I dunno how I'll replicate those cracks or the worn down shape of the planks, especially as I'll likely be using stained pine wood due to cost.
Again, thanks.
EDIT - I just began reading the thread you specified and saw that they have a few ideas on weathering it and detailed info.
