Re: Spider-Man Footwear Question - HELP
Goldbond powder or baby powder (swamp ass is nasty) then compression shorts. If you're still bulging, add a cup or wear a full seat dancers belt. I have tried both dancers belt and a cup. By far dancers belt is a lot more comfortable vs a cup. Having the cup pressed against somewhat limits some mobility and flexibility. Let alone sometimes can cause injury due to being pressed too tight and it can rub you the wrong way leaving red marks to small lesions. Alternative is compression shorts and some craft foam to "smooth" out the region. I'd say grab yourself some goldbond or baby powder be generous, good compression shorts with a nice smooth shape (if you're going the foam method) or cup/dancer belt.
Shoes, it honestly varies. Depends on how "accurate" you're willing to go vs comfort vs price.
Ive seen several builds with water shoes, flat sole glued to the bottom while the inside of the suit uses those gel inserts etc people are creative. I overall go for comfort due to the heat and humidity that can literally heat stroke you D:
