Vandalia
I am a massive The Thing fan, and over the last couple years I've slowly become addicted to sourcing screen accurate props and costume pieces (some more obscure than others). I've been wanting to share my findings to see if anyone else has anything to add. I have a some-what goal of trying to source everything relating to Macready, The Norwegian, Garry, and Palmer. Any little screen accurate knickknacks or bits and bobs that scream "John Carpenter's The Thing" to me I also like to try and source. I'll go through my current collection, and hopefully continue adding pieces over time that I acquire!
(1) Childs and Norwegian Coat
The first of my main discoveries came from the Outpost #31 website, where under the "Cool Stuff" page, had an alleged screen-used Keith David (Childs) Jacket.
I noticed that it still had the tag inside, so I began my search on eBay to locate a close enough logo match.
I eventually did indeed locate the correct brand! Which eventually led me to a listing for a blue coat at a ridiculously good 80$ pricetag... (sadly a current listing is much higher)
The coat I located was virtually perfect!
Here are a few pictures I took of the coat I received. The only major difference between the alleged 100% screen accurate one, is the interior lining is different on the original, with five ridges on the bottom and some kind of interior pocket(?). That being said, I am perfectly happy with my coat, as it appears to be perfectly screen-accurate on the outside. It is perfect for Childs and the Norwegian! As they both wore that same style of coat, as did most of the production crew...
It is worth noting that the Norwegian costume has two versions, the pilot and the passenger.
<- Completely different snowsuit.
<-Correct Coat (The same as Childs)
This coat is absolutely amazing for winter, and makes me totally ready for any mutating monsters I may find...
