Nice, which did you get? Still waiting on mine to shipJust got my notification, can’t wait!
We were originally going to make a template for that purpose, but we purchased 3 different alice frames and discovered that there were slight variations in the measurements on all 3... So we decided it would be a safer bet to just use the holes in the motherboard as your template... So basically just put the alice frame flat on the board without using the spacers, make sure the center bar is centered with the top holes, use the bottom 2 bolts to hold it in place, then mark your the top holes from the other side... Hopefully that makes sense. And i would definitely recommend using a center tap to mark the holes before drilling.Is there a template for where to drill the holes in the Alice frame, or just eyeball it with the holes in the board?
Do you send the tracking numbers via email?More boards including some painted are shipping out this weekend... Do you have an order number so I can double check for you?
Beautiful!
