So... I've been wanting to tackle this for a while but with my new job, prop time is scarce. If others also want this, it would be a good inspirational bump to get it finished.
FTL key from RD Moore's Battlestar Galactica. 3d printed on a professional machine (same type ILM uses) on professional-grade resin .
(I think I've figured out a way to do accurate crystal emitter rods now that the real ones are impossible to find... worst case they'd have to be regular acrylic rods but I'm almost sure I can do 'em, but only if I get a few committed to the project 'cause I can't afford the cost of busying a new clear resin setup to test my theory otherwise. I am currently waiting on a supply of clear resin to try the technique. In the meantime, the photos below show my "worst case" option!)
I decided to do the version with TWO milled grooves in the side. (Note that I even replicated the wonky front of the lower groove, likely caused by over-polishing!)
Cost is $260 shipped.
(Those with * signed up before the model was finished and will therefore get the lower estimate cost while I collected interest due to the trust they placed in me by committing to the run sight unseen.)
As of now (April 21) this is an active run.
Confirmed signups:
Unterprise0216*
Brundlefly*
gregday*
andreasp*
Here's the finished model (using my "worst case" emitter rods):
And a video:
NOTE: the lower clear emitter should of course sit further back... I just stuck them in to take the video and haven't glued them in place since I'm waiting to try the resin versions.
- Assembles in four main parts: top, bottom, rear block and button. (Emitters will either be fully 3d printed or acrylic tube with optional inserts)
- The main body is held together with two allen screws.
- Electronics are included (two blue leds, power switch and battery holder). This is super easy to solder together!
- Two allen screws will be included, m4 and m3. (I'll also tap the parts.)
Confirmed signups:
Unterprise0216*
Brundlefly*
gregday*
andreasp*
And a video:
