Boba Debt
EDIT 2/5/2014
I ordered the grips and I added 15 sets to my original total
Best case scenario these will come in the next contained from Spain which is due in March 5th
So if you want a set send me the info requested below.
My run coincided with a production run so if you miss this opportunity it may be a while before I can get more.
Thanks
___________________________________________________________________________________________________________
These will be $30 per set plus Shipping from Spain and Shipping to You
What does that mean
I can not get a cost for having them shipped to the USA from Spain until I know how many sets we want.
So basically I will just split the cost of shipping from Spain to me with everyone in the group.
Example - If it's $80 and we have 52 sets sold it will be an additional $1.53 per set
If you would like to get on this I need you to do the following 2 things:
1. POST BELOW
2. Send an email to bobadebt@ec.rr.com with the following info:
Subject: Denix Wood Grips
Do not use the RPF email system, I need a direct way to email you so just click my email link above.
For now, I will just create an “interested” list but once I have 35-50 sets reserved I will contact everyone ask that they confirm their reservation.
If enough people follow through I will start to collect payments and order the grips from Denix.
Thanks
CONFIRMED: (List Number / Qty of Grips / Qty of Hardware / Qty of Labor / Paid / RPF ID)
06. 1 / 1 / 0 / Paid 01-20 / phase pistol
25. 2 / 2 / 2 / Paid 01-14 / Cenobyte
01. 2 / 2 / 2 / Paid 01-14 / Shipped 04-28 / Received 05-01 / QCWolf
02. 1 / 1 / 1 / Paid 01-14 / Shipped 04-28 / Received 05-01 / DBoz
03. 2 / 2 / 2 / Paid 01-14 / Shipped 04-28 / Received 05-01 / Spheric Thor
04. 1 / 1 / 1 / Paid 01-14 / Shipped 04-28 / Dokken8
05. 2 / 2 / 2 / Paid 01-14 / Shipped 04-28 / KhalDrogo
06. 2 / 2 / 2 / Paid 01-14 / Shipped 04-28 / Received 05-01 /Scott D
07. 1 / 1 / 1 / Paid 01-14 / Shipped 04-28 / count0break
08. 1 / 1 / 1 / Paid 01-15 / Shipped 04-28 / Curmudgeon
09. 1 / 1 / 0 / Paid 01-18 / Shipped 04-28 / Received 05-01 / Kevin Gossett
10. 1 / 1 / 1 / Paid 01-18 / Shipped 04-28 / Received 05-03 / Darth Brass1
11. 1 / 1 / 1 / Paid 01-19 / Shipped 04-28 / droidgeek
12. 1 / 1 / 1 / Paid 02-08 / Shipped 04-28 / Received 05-07 / eltee
13. 1 / 1 / 0 / Paid 03-02 / Shipped 04-28 / Received 05-01 / Lindy
14. 1 / 1 / 0 / Paid 03-25 / Shipped 04-28 / Received 05-06 / t1made
15. 2 / 2 / 0 / Paid 03-29 / Shipped 04-28 / Received 05-01 / Prefect42
16. 5 / 5 / 0 / Paid 01-15 / Shipped 04-28 / Ripstick
17. 2 / 2 / 2 / Paid 01-14 / Shipped 04-28 / Poseidon11
18. 1 / 1 / 1 / Paid 01-22 / Shipped 04-29 / Received 05-02 / monolith21
19. 1 / 2 / 1 / Paid 01-18 / Shipped 04-29 / Cameron
20. 3 / 3 / 0 / Paid 01-25 / Shipped 05-01 / captiansolo
21. 1 / 1 / 0 / Paid 01-23 / Shipped 05-01 / Magoo
22. 3 / 3 / 0 / Paid 01-25 / Shipped 05-01 / ObscureReferenc
23. 1 / 1 / 1 / Paid 02-11 / Shipped 05-01 / Jedivigneri
24. 1 / 1 / 1 / Paid 01-14 / Shipped 05-02 / bigantkl
25. 1 / 1 / 1 / Paid 03-21 / Shipped 05-02 / Protoss
26. 1 / 1 / 1 / Paid 01-15 / Shipped 05-02 / Magura
27. 2 / 2 / 0 / Paid 01-18 / Shipped 05-02 / Country Paul
28. 1 / 1 / 1 / Paid 01-17 / Shipped 05-02 / Spacemunkie
29. 2 / 2 / 2 / Paid 01-15 / Shipped 05-05 / Gatekeeper
30. 1 / 1 / 1 / Paid 01-20 / Shipped 05-05 / TazVader
31. 1 / 1 / 1 / Paid 01-20 / Shipped 05-05 / podman
32. 1 / 1 / 0 / Paid 01-22 / Shipped 05-05 / Stormleader
HOLD FOR ROTJ AP
01. 2 / 2 / 2 / Paid 01-14 / Caveneau
02. 2 / 2 / 2 / Paid 01-16 / Don93
03. 1 / 1 / 2 / Paid 04-04 / Taco-Bot
04. 2 / 2 / 0 / Paid 01-14 / tonelar
05. 4 / 5 / 4 / Paid 01-16 / JetSetWilly
06. 1 / 1 / 1 / Paid 02-13 / Stefan Jones
07. 2 / 2 / 0 / Paid 01-29 / Jonas
Front & Back of the Wood Grips
Denix: obviously a perfect fit:
MGC: These will be very easy to modify for a perfect fit. You will Just have to radius the top, forward inside edge
I found these on eBay for $2.50 a set
Grip Screw and Brass Escutcheons Set
I received a sample of the Grip Screw and Brass Escutcheons Set and installed it in a set of wood grips from a deluxe Denix Mauser
IT WAS EXTREMELY EASY
I drilled a 1/4” hole straight through each grip with a fostner bit. There was no reason to stop drill the hole because the counter-bore on the back of the grip leaves a thickness just deep enough to press the cups flush
Then I used a soft piece of wood and my thumb to press the cups into the grips.
I drilled the center web so the bolt could easily pass through it.
I set the grips in place and tightened the bolt. The web prevents the cups from pulling together so there doesn’t seem to be any reason to reinforce the counter-bored area to prevent this issue from happening.
Knowing that an MGC does not have the web, if you wanted to install these grips with this hardware on one, you would have to add a disk of material to the counter-bored area to prevent the cups from pulling through the grip as you tightened the bolt.
I’ll buy a dowel rod and glue a thin disk of it in the counter bore and that should solve the problem.
I’ll post pictures of that process once I do it.
Now I just need denix to return from holiday so I can work out the details of buying the grips directly from them
Thanks
What does that mean
1. POST BELOW
- Forum ID
- Full Name
- Address
- Quantity of Grip Sets Wanted
- Grip Screw and Brass Escutcheon Set Option Yes/No
- Install Escutcheon Cups in Grips - $5 per set installed - Yes/No
Thanks
HOLD FOR ROTJ AP
