Laser Brain
Re: Avatar MBS-9M .50 Cal (Tri-Barreled Machine Gun) WETA
Thanks guys
I am going to do the base. Not the floor standing tripod though...just a pivot point that would be mounted on the Hydra.
I'd like to make the ammo box too, but we'll see.
This is the underside, where the base will be mounted to. I'm going to weld up the tubular metalwork and square base in steel and bolt it to an aluminium pivot that will attach to the gun with steel threaded rod..
Here's a shot of the gun tied in with some fresh primer...
The ammo pattern will be pretty easy to make. I'll make 2 links, mould them, cast them in resin until I have enough for a decent length. Then I'll join them, remould and cast in a dense, self-skinning black rubber.
Thanks guys
