zombienoms
My last project I used sheets of thin craft foam for certain parts of my suit, the results turned out less than desirable. Basically parts ripped and didn't perform as I hoped. I was thinking this could be due to thickness of the foam I think it was maybe 3-4mm. But this may have also been the type of foam as it was craft foam from an art store and not EVA workout mat.
I wanted to see if I should try my hand at foam again as for sections like abs and neck it would be nice to shave some weight and have some flexibility. But I don't want to sacrifice durability be it from rubbing against pep pieces or up and down movement and I especially don't want tearing and weak points.
What foam should I get, what thickness anything to look for or keep in mind? Am I expecting too much out of the material?
