Weirdest fetish video ever.![]()
I would think a balsa wood rod would snap from simply a quick movement let alone contact.
As for spinning, I would think the rod and attachment would need to be perfectly centered or the tip would wobble wildly. A 3 foot rod off center by only a few millimeters at the base would cause a huge wobble at the tip. The lightsaber rods don’t seem to move much and remain essentially straight.
There has been something niggling me in this thread since post #46 about whether the V2 emitter rotates in ANH. I checked haliwax's ref's but couldn't see one way or the other but I was sure I'd seen something, while looking for something else, where the emitter wasn't moving. I've found out where now - 'birth of the lightsaber' Ytube vid from 8.52 on you can see the emitter face - there are marks near the edge, notably at the bottom, that remain still despite OB1 moving the hilt about & if you go frame by frame it's clear the blade is rotating. I've strung a few frames together to show this - look for where the cursor is pointing for the mark.
So this is evidence that V2 emitter didn't move for ANH? if so are we sure it moves on the prop as it is now? if so how did that happen?
or is this not the V2?
Isn’t that white mark on the top of the Faux cane area?
That said, if you look at the Obi solo shots of the tail end of their fight outside of the hangar bay, I DO believe I can see the full emitter spinning, but it's too small in the frame to make a definitive judgment call
Sorry, this is not my area of expertise but what is the reasoning that the blade rotates? Aren't the blades rotoscoped and "painted" with movement. The only thing I remember anyone saying about the blades was that they were covered with reflective material similar to projection screen s that the camera would pick up the correct position and perspective.
If the bade is rotoscoped or painted over wouldn't this obscure the real blade as was the intention? Isn't the rotation or spin just a painted artifact?
What would a spinning blade do except break ? ; )
Excuse my lack of knowledge...
That was a typo. Faux "Vane". Meaning on the hero version, the area that is the spinning vane of the grenade section (but does not spin on the prop).
