thanks that sounds great! And yes I think the pic I posted was fan made! I think Roland made a file for them in the bttf paper props section, not sure if there was a back on them, maybe someone may have more information or seen a picture of a screen used card.... thanks againI'll knock out one of these later today and post the results here.
Since there is only the front shown on screen, I may make our own back version since the example you show is just a fan creation, right?
That is awesome thank you so much..... dose the more rounded corner version have the same back? Just so I know before I make my orderHere is our version of the Cusco Card:
https://i.imgur.com/SrXYwG8.jpg
In lieu of the original prop bar code, I used the UPC code for the BTTF2 DVD.
https://i.imgur.com/XrMPePe.jpg
That is a genuine magnetic strip so if your bank is willing, you could load your debit card onto one of these for fun.
The original had very rounded corners, so here is the more screen accurate "extra rounded" version:
https://i.imgur.com/JUL5EjR.jpg
Can be ordered here: http://www.magnoliprops.com/cusco-credit-card-cards-p-579.html
Kind regards,
Magnoli
thanks again and great job
Will you be changing the barcode numbers to match the screen used card (same as Roland) if so I’ll wait for the change then make my order.... I do like the more rounded cornersYes, it's the same card just with corners cut more. To be honest, cutting the larger corners isn't easy with our normal cutter as these genuine PVC cards are harder to cut through. We'll be leaving them with standard corners unless specifically requested as it's quite a pain to trim these... we'd rather leave it to the customer whenever possible.
The bar code on the front side of the card is almost the same as the bar code on the almanac receipt. On the Blu-ray screenshot you can see that they used the same bar code for both props.
Thank you I’m sorry to be a pain but as you know here the more screen accurate the better, thank you for your patience! Let me know when everything is done and updated and I’ll make my order and thank you againGood catch! I'll update our card accordingly.
Hello I tried to make an order for 2 cards, I made an account etc read the payment information to confirm you except PayPal, I got to the check out but there was no PayPal option.....Good catch! I'll update our card accordingly.
Got mine very happy with them! Thanks
positive feedback incoming
View attachment 815645View attachment 815646View attachment 815647
You will not be disappointedTotally forgot to order mine. I've been traveling too much. If only I had a time machine...
Anyway, thanks for the reminder!
