Lacrima 99 Shock Rifle - Aliens 4- 3d design and print
paulsboutique
Thought Id have ago at the Lacrima 99 from Aliens 4. Its quite a straight forward build, no moving parts, not based on anything, but looks pretty cool and the heavy weathering could go the wrong way ….
Soo ... CAD shots for progress....
I used 2 x 12mm aluminum tubes for the barrel. This also allows you to mount the additional under barrel attachment
I designed it around a solid interior and outer shells to allow for easier printing and to give some depth to the model.
Right... so its gets a bit murky here as i forgot to take photos along the way ...
The prop store original of this build is heavily weathered and i wanted to go down that route.
I was looking for a flakey, chalky, crazed finish with lots of grime over it.
To get the crazed look I sanded down the clear in various places and hit it up with a few coats of white in the hope it would react with the paint underneath.
I then sanded this down to get the crazed paint look
