Well I
finally got the parts and I’m little defeated at the moment to be honest. My morale is a little low and the wind has been taken from sails a bit. First they didn’t ship all the parts. To be fair there is a
LOT of them and some are really,
really small. I do attach the small ones together and snip them apart when they arrive to try and minimalize this as much as possible but the grips screws simply didn’t arrive. They where never placed in the shipping box..
I’ll start with
positive.
•The model itself that Carson was so generous in sharing is
absolutely beautiful to see in person and perfectly in scale.
•In order for these prints to fit together I had to rescale them a bit and that worked out really well. Everything slid nicely into place for the most part.
•This next here was a really pleasant surprise. Simply learned that I can design the tap/die right into the models themselves. AND.. it works perfectly right out of the box!
•The Bull barrel/Flash hider idea honestly also works really well. I wanted it to be
“lose” like the original prop but I didn’t want to to angle down.. only up. I also wanted to be able to rotate it so it would sit off center and all that worked out great.
•The sight also works as it should.. I do need to reworked the tolerance so the button itself works better but overall it’s nice.
•The Lockframe works as it should, including the safely.
•The grips themselves came out and attached really nicely to the Mauser itself. Just need those screws..
•I didn’t design the tap thread into the Mauser for mount holes but now I know I can which is great. But the positive here is I wasn’t sure if there would be enough material to hold the back screw. I tapped the hole the old fashioned way and then attached the screw itself. It holds just fine and without interfering with the Lockframe at all..
Now the
negatives..
•Cost. This one is all me and I know what I’m getting into but still this print is over $200 alone. MJF is very expensive but it’s also really strong. Stronger than most realize I believe so it’s worth it on my end because I don’t have worry about it breaking. But because it’s so expensive I really wanted to get everything right this first time out of the gate. I’ve been sitting on ordering the parts for a little while now double checking everything as much as possible to minimize any issues. But unfortunately I did miss some important details.
•Trigger.. I didn’t take into account (
or more importantly fully understand) how it actually works. In theory yes but practicality.. no. Trial and error but damn. The trigger doesn’t hit the hammer release mechanism unfortunately. So at this moment it does not work as it should. Ugh!
•The bolt slide. Carson mentioned how he modified his Mauser so it could not and would not be functional. One of the things I didn’t notice until the print arrived was how his slide worked. I didn’t realize It only goes back a little ways and is restricted by the design itself. I thought maybe I could modify by cutting some material away but no.. I’ll have to modify the design itself so the slide isn’t restricted.
•There is a few other minor issues like not having the lettering or numbers deep enough for them to really stand out but that’s to be expected with Nylon prints. With resin prints these details would come out crisp and perfect but for some reason the basic grey print doesn’t seem to capture as much detail as the black
(which is simply a dyed grey). Maybe it’s the color itself but the Grey for what ever reason doesn’t seem to be as predominant..
I know the positive definitely outweighs the negative but I can’t help but feeling a little disappointed at the moment. Live and learn..
