JRX
The best cutting attachment for the Dremel is the diamond coated cutting wheel. It's only $15 but it is SO worth it. It cuts through just about anything like butter and I've not needed to use any other cutting wheel since.
I second that - the Diamond coated Metal cutting wheel is totally worth the
investment - I rarely use anything else for cutting anymore.
But if you want to use a dremel on Plastic those cutting wheels would only
"melt" it as they get pretty hot, so the grinding sleeves you can put on the
rubber wheels work a lot better to take away material from plastic.
I for my part would do it with fine goldsmith saws and Surgery knives - that
leaves you a much cleaner surface on the plastic (but is indeed more work).
