Unlimited Run Reverse Flash Ring and Flash Ring $60 Polished Brass & opening version
replicaprops
Official Licensee
CLICK HERE TO PLACE AN ORDERIf you do not see your size listed, just let me know what size you want and I will adjust the model for youPolished brass is under $60.00. for most popular sizes.Smallest size is 8.5
Reverse Flash in polished brass
Regular Flash in Polished Brass
Here are some customer supplied photos
original_114340_83158_1421896756.jpg10966662_842752152458908_1545210319_n.jpg10981863_10203944986920708_8483516675095660_n.jpg10944592_832583656801391_2135437683_o.jpghttps://www.shapeways.com/shops/replicaprops?section=TV+Props&s=0
Also, even though not shown yet, here is the same ring but with the lightening bold put back in the proper orientation to be "The Flash"
Here is a version that is opening. Only one size available due to hardware compatibility
Right now I only have 1 size (size 16) which should fit over a glove .
The compartment inside is 15.5mm x 12mm x 1.2mm deep. So you could put a micro sd card in it or make a micro flash costume.
CLICK HERE TO ORDER THE BASE
CLICK HERE TO ORDER THE REVERSE FLASH TOP
CLICK HERE TO ORDER THE REGULAR FLASH TOP
Here is the magnets you need
Here is the hinge you need, select the 06mm from the drop down menu
Re: "Reverse" Flash Ring
Is this based on the actual prop? The band looks way too wide.
Reel
How do you figure it is too wide? Please post a photo of what you are referencing off of.
Thanks.
Rob
Oh, I actually see why it looks too wide. I forgot to taper the band. Fixed that. Thanks for pointing that out to me.
Nicely done! This is definitely going on my wishlist. If only shapeways could manage a working hinge in their 3d metal service!
They sort of can. I managed to make a working hinge for my "The Island bracelet"
The trick is you have to make the parts in separate models and then like I did in the bracelet, use a spring loaded watch pin. The method works quite well.
Re: Reverse Flash Ring and Flash Ring <$60 Polished Brass
Thanks for adding the extra detail ring! Looks great! Order placed.
Do you have any photos of an actual ring yet? Would love to see how it looks in person as opposed to digitally :)
Not even close yet. Shapeways takes 3 weeks to deliver. But lots of people have ordered in the last 24 hours, so I imagine real world photos will be in about that time frame.
I have however done lots of prints with shapeways and they are 100% accurate to my designs, so I can't imagine the real world view varying any from my design.
I will post a picture of mine when I get it. Ordered in silver though so it may not be what you want. Different materials will look different from shapeways. Some have heavier print lines than others. Mine is expected in January.
Well you did yours in Premium silver, so it should have no print lines. That should be stunning.
Yeah. I want to wear it and personally had problems with wearing brass and turning green under the ring. I am sure the plated option would work fine. I'll still post pics of the premium silver.
Very cool. Thanks for the reply!
No problem.
Some times shapeways ships in less than 3 weeks, but it is the holidays so it is impossible to say how long now.
Understandable. I was just curious. I'll be keeping an eye out for it because I really want to get one after the holidays.
My ring got cancelled by Shapeways. Perhaps they can't polish it that much.
No, it was this part
It did not show up in the online warning, I am working with an engineer from shapeways now to find out how to fix this. Looks like it is somehow kicking back as a emboss rejection. Might be because the edges are sharp.
Let me figure it out and Ill let you know when it is fixed.
Got it all fixed now. Looks better too, so maybe this was the best thing for everyone.
