Hey man, nice build so far. Did you use foam and do the outside with cardstock for the helmet? Just curious because I've been wanting to do the same thing.
What about using some heavy gauge wire to shape the cape?
wouldnt 2 layers of floor mat foam be way enough to hold it? i mean, those things are pretty sturdy, it seems to me. you could even do 3What type of wire do you suggest? Even if it shapes the cape into an arc, how would that then attach to my body / the chest piece? I suppose I could build some sturdy shoulder piece that fits over my head (kind of like football shoulderpads) and then bolt/velcro the cape to that.
I'm not sure how I can achieve the arc and support the weight at the same time with just the foam.
yeah the 4 mm stuff is too thin but seeing as the base of the cape is pretty thick, like 2 cm, that would be 2 foam floor mats i tried their hardness yesterday by chance as i never worked with it, and those are really sturdy, and im sure they would hold the weight of the cape, and you could velcro it to the chest. ill whip up a quick explanation what i mean, 1 secYou may be right. All I have right now are a couple of sheets of 4mm foam. I'll check home depot today to see if they have a square or two of the floor mat foam.
edited for amazing paint skills: i hope you get what im meaning:
Dead link, any updates?I found my template here:
https://sites.google.com/site/pepcodex/random-helmets
Hope it helps you out!
Are you putting the chest piece on top of another foam or are you attaching that to fabric?Pieces need to be glued, painted and trimmed, but this is the basic layout. I'll need to strap them together in the back with luggage straps and more foam to have them fit on my body, and probably do some shoulder reinforcing to support the cape. (Don't mind the dog cage underneath, I'm tight on space!)
