Construction is almost done on mine, just need to do the transformers. Did anyone else have trouble with the fin alignment plate? My fin assembly is slightly skewed, and it took a lot of work to get them in there. I had to taper the fins themselves
It sounds like you both have saved the rest of us some work. thank you.
I'm still filing the parts down.
Those longer bolts need to be trimmed down. It's one of the earlier steps in the instruction pdf
Great idea! I'd defenitely be interested in a piece of that shim. I'm in Belgium, but would be happy to pay for shipping and a bit more ;-). Drop me a PM if that would be possible.I also have a larger piece of brass shim stock on order so I can have the brass tabs tuck under the wire on the transformers - the tiny brass squares seem to easy to mess up. Plus the brass wire soldered to the brass shim would be a bit structural and look identical to the squares. I have enough shim that I can send anyone on this build list who wants some for free.
Another question: what do you guys use to paint the alu parts black? Spray paint? Brands?
Hey kursosawa, should the int list in the first post be up to date? It says that I only paid the deposit, but I made the full payment days ago. Just wanted to check if you got it...
