<div class='quotetop'>(swpropmaker @ Oct 12 2006, 07:27 PM) [snapback]1336937[/snapback]</div>
OK guys... the VAders TIE was painted the same color as the TE Fighters in a New Hope. The base color is grey. The trim is dark grey. Krylon stopped making the equiment grey primer that was the base color but walmart sales a colorplace brand Grey Primer that is perfect for the standard ANH TIE Fighter. The trim pieces are Krylon Grey primer (Dark Grey)
Ive got some really good shots of vaders TIE and its grey there is not even a hint of blue to be found and on screen the TIE's all look the same color.
There is no doubt in my 8 years of research that the ANH TIE's were painted Krylon Equipment grey primer (discontinued in 1979) The above Walmart brand is the clostest i could find using chip samples from Vaders TIE.
The ESB TIE is also an out of production (Mid 80's) Krylon Slate Blue color. Ryan has found a color that matches but only comes in satin so it has to be dulled down with dull coat. The trim pieces match the Krylon grey primer color.
ROTJ Interceptors were painted with the Krylon slate blue OOP and the details were painted with Krylon grey primer. The only change was the canopy it was painted flat black.
Thats my two cents on painting TIE fighters.. it may be right... then again it may be wrong but its the closest I could come up with. In the end find what you like and recreate it the best way you can. Do tests and see what works and what doesnt. A TIE your happy with is all that really matters.
Steve
[/b]
Steve-
I got the ColorPlace Equipment Gray (20010) as you suggested when I got my kit, and did some tests, but it did come across to me as having too much "warmth" to it. I got another primer, Rustoleum Gray Primer 7582 which is what I ended up using that had the cooler look to it, and reflects light nicely with the subtlest touch of "blue" because the primer has a cool tone to it, instead of a warm one.
I would invite people to try testing both to see which the prefer in how the colors reflect light. In the end they are only $2.50 a can and you can see how natural light reflects against both.
And the Krylon Equipment Gray Primer (1318) you guided me to is the best match for the highlights. I had to special order it online though because it's hard to find in hardware stores.
I don't like the slate blue color of the ESB or ROTJ fighters but that's apersonal preference.
JV
<div class='quotetop'>(Hand Solo @ Oct 12 2006, 09:10 PM) [snapback]1337000[/snapback]</div>
I offer this scan I made from page 29,
From Star Wars to Indiana Jones: The Best of the Lucasfilm Archives, A New Hope section...
Note that even the TIE proto is painted a blue-grey.
[/b]
Although that photo is in the ANH section of the book you found it in, check the outer frame edges of the wings... they have a double layer, which is indicative it was an ESB produced model. The pics of the ANH fighter I have found do not have that double edge on the outer frames. I found these quickly in a Google search but have seen larger copies of these pictures, when I get to my office later I will post the hi-res ones I have on my computer there. But these pictures are of the ANH TIE. It's not blue.
If you can find higher res versions of these pictures before I can post mine to see the difference between the outer edges of the wing frame on an ANH TIE and an ESB one you will see what I mean.
Steve's point about the Vader TIE being the same color as the other ANH fighters is dead on. Why would they paint Vader's gray and the others blue and then they all look the same color onscreen in ANH? The standard TIE on display in the MOM exhibits is an ESB model which is what is causing the confusion.
And Kurt, as for why they may look slightly blue in ANH is influenced by studio lighting, blue screen reflection, and the film stock.
JV
