Well, there are a lot of TIE threads in the SS section, so I decided not to start a new one.
Here are some buildup pics of my SS cockpit. Since I could never top JV's "set" cockpit, I decided to go for the look of the filming model. Steve's kit has a nice, accurate insert. But, I wanted to incorporate the upper cockpit detail from the available reference pics. Remember, Steve originally designed his kit without a cored hull. He added that later by request, IIRC.
My goal was simply to kit-bash something that looked reasonable. Not accurate, reasonable. All of these parts are painted with Krylon 1318, All Pupose Primer Gray. I painted them late last night, then noticed that the finish was chalky. Paint, or garage, or both, must have been slightly too cold, or damp (it was raining heavily outside as I was painting). So, I had to strip them down and start over.
In the first pic, starting at the 12 o'clock position, I built a ceiling (practically invisible when installed), a false wall for the hatch (to provide a sense of depth), a window insert (I didn't have to, but it was fun), and added some upper cockpit details inside the hull. I also scratched the triangular doo-hicky that attaches to the upper cockpit frame. I was on a roll. Kits scattered hither and yon around my table and gallery. At one point my 12-year old came in, looked around and said, "You have too much going on in here."
I've got a Harrier on order, should arrive in a couple days. I plan to paint the pilot figure a solid, slightly darker gray (Rustoleum Dark Gray Primer), then check how it looks installed. I have yet to put the cockpit together. Still awaiting the pylon mount, then I need to find a threaded square. Again, this isn't an accurate replica of a filming miniature. Just an approximation that, hopefully, inspires a sense of the originals.
Anyway, on to the pics:
[image]http://home.comcast.net/~imaginager/tie/comp.jpg[/image]
[image]http://home.comcast.net/~imaginager/tie/insert.jpg[/image]
[image]http://home.comcast.net/~imaginager/tie/cpit1.jpg[/image]
[image]http://home.comcast.net/~imaginager/tie/cpit2.jpg[/image]
[image]http://home.comcast.net/~imaginager/tie/cpit3.jpg[/image]
[image]http://home.comcast.net/~imaginager/tie/cpit4.jpg[/image]
[image]http://home.comcast.net/~imaginager/tie/cpit5.jpg[/image]
And, what the pilot's view:
[image]http://home.comcast.net/~imaginager/tie/inside.jpg[/image]
