Just got my Denix, this thread is now my bible for fixing it up xD
Next up are those two notches that go on the sides by the bolt. Anyone know what they are there for? Do they have any function on a real mauser?
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1285_zpsxntmoaq1.jpg
Thanks guys! Next up on the chopping block is the site. I popped the slide off and filed all the edges to get rid of those ugly seams. I also took off the "butt". I got it down as far as I could without cutting into the hole for the pin. You can't really tell in the pic but I also rounded the front end a little so it's not so squared off and more like a real one.
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1306_zpsjixrehi0.jpg
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1313_zpsteezhhyo.jpg
I'm going to darken and weather it a little bit with some perma blue.
Eh? How did you get that off.. seems welded together or a single piece to me?
Has anyone used a file or a really thin saw to cut straight notches where I marked off red on this pic?
that would give the illusion of a separate piece that the real gun has?
jus thinking you could tape off the gun and make small cuts with really really thin saw to give the nubs a "T" look
Mine really doesn't have anything to prise open I don't think? Maybe the MK2 Denix is different?
Don't really have a photo to hand so zoomed into another pic.. can't see any join lines...https://uploads.tapatalk-cdn.com/20180122/5baca0fff4cf724436f96d1accf342aa.jpg
Sent from my ONEPLUS A3003 using Tapatalk
The slide? It's two pieces pressure fit together. Pry them apart with a small flat head screwdriver.
I remember seeing a guy here who actually cut out the whole hammer assembly like that to make it look like an MGC or a real Mauser. Can't remember what thread it was in but it was awesome.
Thanks for the compliments. Much respect to you guys, so it means a lot.
Still working on the finish, but man, that metal is smooth now. I got rid of all that nasty pitting. Detail is still pretty sharp, so things are looking good.
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1305_zpskxpdx4qu.jpg
Sorry to resurrect an old thread, but belated congratulations on a terrific build!
I was just wondering if you had any tips on how to prevent a Bespin scope/mount from moving back and forth, as it's only a single thread? I use a washer/spacer, which helps a little, but the weight of my M19 scope still makes the whole thing pivot back and forth.
I've had this Denix for a long time, and it's way overdue for an overhaul. You guys know how bad these are. All the edges are extremely soft, pitting everywhere, etc. I've going to strip it down and sharpen all the edges, clean things up, and add some detail. I've got some old Blast-Tech parts I can reuse and a new knurled disk coming from Boba Debt's run.
Before pics. Typical Denix. I'm getting rid of the left side greeblies.
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1165_zpswvipnek5.jpg
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1166_zpsxrjrdlsd.jpg
I got a set of the brass grip hardware on ebay for $5. I'll be sticking with the plastic grips for the time being since they fit correctly.
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1164_zpsywmbl3qh.jpg
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1167_zpsianrcdan.jpg
I took everything apart and started to sharpen angles and clean things up. I'm filing everything by hand.
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1169_zpsv2djkg8m.jpg
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1172_zpscnfrkvni.jpg
Things are shaping up.
http://i82.photobucket.com/albums/j243/mattycairns/IMG_1182_zpsvokisuz4.jpg
Lots more work to do, but the results are pretty good so far.
