Uncle
To weather the chains, I'd suggest spraying them with some rust colored primer spray paint from about 18"-20" away. And try to not cover every square inch.
Then, another very light spraying with a flat black.
Last, take a small wire brush or file and lightly scrape through the paint in a few places to show the lines of metal. It should look worn and mistreated, but still in use.
Side note: if you have an airbrush, you can use cheap acrylics and anything you don't like you can wash off with Simple Green.
