Re: SS Lambda Shuttle
Ummm... Well - if you need it spelled out for you:
E-I-G-H-T F-O-O-T S-T-A-R D-E-S-T-R-O-Y-E-R
Hmmmm you're probably right Rob ! :lol
Thanks guys !!
Neil, unfortunatly I had to make a whole new cockpit
When I put a pic of my shuttle over a pic of the original, my cockpit was way undersized (was missing more than 20 mm in lenght and at least 7-8 mm in width) :
I think I haven't trimmed well the parts you sent me because on pics of the shuttle pics, the cockpit doesnt seem to be as short as mine was.
Well I tried to add some strip of styrene to enlarge it :
The result was good and proportions OK :
Unfortunatly the front was uneven and after all those modifications it was weak and the underside was ugly (and it can be seen :/). I was close to give up.
So I decided to make a new plug and vacform a new cockpit :
Pull done :
Roughly cut :
I'm quite happy with the proportions, unfortunatly I havent nailed the horns areas as good as Neil did. But well nothing is perfect...
Found all the parts of the rear bulkhead, the small barrels between the turrets are missing, I know I still have at least 4 of them (used the other to build the shuttle guns) but once again I don't know where is the sprue... There're are 2 sprues with those parts in the kit, and of course in the box I have only one sprue where all the barrels are missing.
Thanks for looking !
