Interest SECOND RUN: Accurate Zinc Cast MGC SW/44 Hammers and Machined Aluminum Nakata Browning Firing-Block Greebles for the ROTJ E-11
Thank you to everyone who participated in the first run of these parts. I will be doing a second run of parts if we can hit the minimum order of 10 sets. I will keep the list open till mid to late February as I have other projects that require my attention. I will be contacting those who are interested for payment a week before I place the order.
I would love a set of these since I missed out on the first run.
As we discussed by PM I'd be interested separately in the Nakata Browning firing-block only, as I already have original MGC hammers on my MGC E-11.
Here are some photos that DarthWilder provided comparing his original parts next to my reproductions from the recent run.
I was just curious, and maybe I missed it in your other thread, but why the difference between original part and yours?
Is this due to a variation in the parts used in the pistol over the years?
I have a theory conceived from my research on this part from browsing several Japanese collecting forums. I believe with usage, the block begins to look more like the original part in the photo due to the mechanisms inside the gun that cause the block to slide back and forth. Often times the forces are so strong on the block that they often crack or break the block in half. There had been a run of brass reproductions produced by a member of one of these Japanese model gun forums to replace the damaged aluminum blocks.
With that said, the majority of unused blocks that I found appeared much like those on the ROTJ E-11 prop, which is reflected in my reproduction.
Thanks for the explanation.
Makes sense : I have a bunch of PFC guns and the die cast not only deteriorates over time but does in some cases, deform.
Yes the metals used were quite soft. Also to note, the machining tolerances back when these parts were produced were much looser than they are today causing small variations in detail from part to part.
