Re: Spiderman web shooter: A collaborative project. Now with wiring diagrams!
opcorn
opcorn
webbing fluid im workin on you make em shoot ill tell u how to make it broopcornwhat kind of fluid are you referring to?
If you're modifying the models yourself, you can upload those to Shapeways. Otherwise, follow the links in the junkyard post to purchase the pieces already on SW.
Oh, thanks...i made a research in the junkyard but i didn't find the page >.<
Can you please tell me what's the name of it? thank you again!
Just wanted to show everyone the Kelly Green RIT Dye.
If the center lense is Red?
And the fluid indicator is Green...
Does that mean you only need white lights?
EDIT: Eh, Im thinking the colored lights will make it pop more.
Bingo chips coming in today!
Also what color is the bezel?
Does anybody know what size the watch pin would be for the bezel.
Thanks
^^^ Thanks for the answer is it possible you could measure it for me? If not don't worry.
About 2cm. You'll need to do a small bit of sanding, but it should be right
