Hello all! We’re offering a new style of belt rig for your ‘Ghostbusters’ ‘84 getup that is designed for heavy use like parades, conventions, and general cosplay.
Mimicking the foam rubber belt circuits seen through the film (mostly any LA filming), these circuits are light, durable, and easier to use than a Sayno calculator. Breaking my own during a convention last year inspired this.
Main holster is laser cut in thick black leather, with accurate dome studs. Foam rubber belt circuit attaches with Velcro.
Main board features acrylic tube ‘nixies’ with appropriate colored wires, securely attached to the upper holder. Each Buster has a different circuit pattern and you can choose who you’d like.
Surplus shaver cord is screwed into the main board, and runs to a resin daughterboard that is securely fastened to a belt clip.
A simple and fun addition to a Gb setup, ready to go out of the box!
You can head over to Etsy (StantzIndustries):
or order here via PayPal link.
Ray
Egon
Peter
Winston is available, we just need to build it and photograph it now that supplies have arrived. Just ask
These take 1-2 weeks to make, molds are made and supplies are here.
OUR BEST ghostbusters' Stunt Belt Circuits for Cosplay, Convention, and Parade Wear - Etsy
An amalgam of the various props used in LA filming, each circuit bears a metallic pattern that closely resembles the ones worn by each Ghostbuster. The main circuit is cast in urethane foam rubber and painted in Flex paints. Nixies are acylic tube, and mounted onto a resin portion of the circuit. It
www.etsy.com
Ray
Buy Now
www.paypal.com
Buy Now
www.paypal.com
Buy Now
www.paypal.com
