Limited Run Aliens Pulse Rifle Parts (Shrouds, Vents, Stocks, Grips, ect.)
I have been working with a friend to create a number of high quality Pulse Rifle parts. They are a combination of known research and our own in order to dial in the parts. These will be limited run and no payments taken until the parts are in hand and ready to be packed and shipped.
Contact me to check on shipping, buy, or be added to the interest list.
Available Now!
Thompson Grip
View attachment 1759672View attachment 1759673
GBP£37.50 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
  • Made to fit the WE-Tech Cybergun GBB M1A1 Thompson. (may fit others but unknown)
  • Original model master incorporating a blend of the features of all the PR grips.
  • Cast in high quality, impact resistant, black urethane resin.
  • Base screw plug cast off a real Thompson grip screw.
10 Available:
  1. Jim - PAID and SHIPPED
  2. Alien War Doug - PAID and SHIPPED
  3. CoCost - PAID and SHIPPED
  4. asoncsm101
  5. Hirohawa
  6. Available
  7. Available
  8. Available
  9. Available
  10. Available
Grenade Launcher Blocks (Prototypes)
These prototypes were made using older information that was available, minor changes were made to the final versions. Added side by side photos for comparison.
View attachment 1759684View attachment 1759685View attachment 1759939View attachment 1759940
GBP£39.00 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
  • Created based on photos/research from the original parts, information from "BugStomper"/Pulserifle.net, and known measurements.
  • Solid machined aluminum, cut from aircraft alloy billet, bead blasted finish.
  • 8 Hole version is 70mm tall, 37mm wide, 25.5mm thick, shotgun barrel hole is 24mm dia., the mag tube cavity in the back is 25mm dia.
  • 10 Hole version is 70mm tall, 37mm wide, 13mm thick, shotgun barrel hole is 24mm dia., the mag tube cavity in the back is 25mm dia.
  • Holes for grub screw 2.5mm dia, ready to tap for M3 (or you can drill larger for a different size)
1 of each Available:
  1. 8 Hole - PAID and SHIPPED
  2. 10 Hole - PAID and SHIPPED
Updated with minor changes from our prototypes
View attachment 1760463View attachment 1760464View attachment 1760465View attachment 1760466View attachment 1760467
GBP£49.00 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
  • 8 Hole version is 72mm tall, 38mm wide, 25.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
  • 10 Hole version is 72mm tall, 38mm wide, 13.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
10 of each Available:
  1. 8 Hole - Jim - PAID and SHIPPED
  2. 8 Hole - DarthWilder - PAID and SHIPPED
  3. 8 Hole - Harry Harris - PAID and SHIPPED
  4. 8 Hole - Alien War Doug - PAID and SHIPPED
  5. 8 Hole - barney five - PAID and SHIPPED
  6. 8 Hole - ObscureReferenc - PAID and SHIPPED
  7. 8 Hole - Available
  8. 8 Hole - Available
  9. 8 Hole - Available
  10. 8 Hole - Available
  11. 10 Hole - DarthWilder - PAID and SHIPPED
  12. 10 Hole - Moosh89 - PAID and SHIPPED
  13. 10 Hole - barney five - PAID and SHIPPED
  14. 10 Hole - ObscureReferenc - PAID and SHIPPED
  15. 10 Hole - asoncsm101
  16. 10 Hole - Space Jockey - PAID and SHIPPED
  17. 10 Hole - Available
  18. 10 Hole - Available
  19. 10 Hole - Available
  20. 10 Hole - Available
Barrel Vent
View attachment 1759932View attachment 1759933
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£20.00 (combined shipping would be quoted separately)
  • Created based on information from "BugStomper"/Pulserifle.net
  • Made from accurate 40mm square mild steel tube with 3mm wall
    • Matching material and specs based on first hand research at Bapty
  • Inner Diameter of the barrel ring is 19mm
  • Milled and welded professionally
  6. 8 Hole - Available
  13. 10 Hole - eethan - PAID and SHIPPED
  14. 10 Hole - barney five - PAID and SHIPPED
  15. 10 Hole - FokkerVF - PAID and SHIPPED
  16. 10 Hole - ObscureReferenc - PAID and SHIPPED
  17. 10 Hole - asoncsm101
  18. 10 Hole - CoCost - PAID and SHIPPED
  19. 10 Hole - Space Jockey - PAID and SHIPPED
Shoulder Stocks
View attachment 1759930View attachment 1759931
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£23.00 (combined shipping would be quoted separately)
  11. 10 Hole - eethan - PAID and SHIPPED
  12. 10 Hole - DarthWilder - PAID and SHIPPED
  13. 10 Hole - Moosh89 - PAID and SHIPPED
Shrouds
Production sample, only lightly buffed, more buffing will give an even brighter look.
GBP£375.00 per set plus actual postage from UK. Tracked shipping to the US GBP£29.00 (because of some logistics we cannot combine shipping these with other parts)
These will be sold/shipped as they are completed/ready based on the order of the interest list, no money taken before hand.
  • Based on photos of aluminum hero shrouds and first hand research at Bapty (cleaned up to be made straight and symmetrical)
  • High quality professionally made aluminum-filled, fiberglass shrouds, and mag butt caps.
  • Uniform thickness around 3mm, STRONG, light weight.
  • Comes untrimmed, with trim lines molded in for tight fit to a Thompson and SPAS cage allowing for individual adjustment for fit.
  • Open access at the top, between the upper 'handles' (track along the top) for you to fit as strong and light a U-channel as fits your build. This allowed us to keep the thickness uniform, reduce cost and weight.
10 sets will be available
  1. DarthWilder - PAID and SHIPPED
  2. Harry Harris - PAID and SHIPPED
  3. mugatu - PAID and SHIPPED
  4. Moosh89 - PAID and SHIPPED
  5. Space Jockey - PAID and SHIPPED
  6. CoCost - PAID and SHIPPED
  7. abaddon
  8. userd1402 - PAID and SHIPPED
  9. Cpl Potter
  10. barney five
  11. Waitlist - FokkerVF
  12. Waitlist - ObscureReferenc
  13. Waitlist - krithargus
  14. Waitlist - asoncsm101
  15. Waitlist - MooseF
  16. Waitlist - Johnnyfl
  17. Waitlist - Jim
  18. Waitlist - OCD is me
  19. Waitlist - JLinNY
  20. Waitlist - holto
Coming Soon!
If you would like to be added to the interest list for any of these I will create a list and those people will have first opportunity to buy when available.
Slings
Photo of the components being used for the slings.
GBP£37.50 per set plus actual postage from UK. Tracked shipping to the US GBP£10.00 (combined shipping would be quoted separately)
  • Screen accurate 8-band webbing
  • genuine period hardware.
10 will be available
  1. Jim
  2. DarthWilder
  3. mugatu
  4. Available
  5. Available
  6. Available
  7. Available
  8. Available
  9. Available
  10. Available
I'd like the last 10 hole barrel vent if it's still available. Could you combine shipping with the shrouds? Let me know. Thanks!
Does anyone know where to source a replica SPAS cage?
Prop It Up on Facebook. I ordered a while back, but I have to say the experience on this thread has been MUCH better dr_slurpee has a list going and we are informed as to where we are on the list and when it's sent. Prop It Up on the other hand has so far been 'I'll get it sent tomorrow' then another week goes by. No clue where I am on the list.
So thank you dr_slurpee for doing such a great job!
EDIT: Looks like Prop It Up has done a spas cage update on his Dirty Garage channel, so all should be good.
Thank you Space Jockey. Yes, I've reached out to "Prop it up"; looks like quality work. I can't wait to get my hands on one! ...and I'll 2nd your thanks to Dr Slurpee too!
Some pics of 3D print of the barrel extension to test it out before we look into costs etc.
  1. Hole - Harry Harris - PAID and SHIPPED
  2. 8 Hole - Alien War Doug - PAID and SHIPPED
  3. 8 Hole - barney five - PAID and SHIPPED
  4. 8 Hole - Available
  5. 8 Hole - Available
  9. 10 Hole - DarthWilder - PAID and SHIPPED
  10. 10 Hole - Moosh89 - PAID and SHIPPED
  12. 10 Hole - barney five - PAID and SHIPPED
  13. 10 Hole - FokkerVF - PAID and SHIPPED
  15. 10 Hole - asoncsm101 - PAID and SHIPPED
  16. 10 Hole - CoCost - PAID and SHIPPED
  17. 10 Hole - Space Jockey - PAID and SHIPPED
  18. 10 Hole - OCD is me - PAID and SHIPPED
Shoulder Stocks
Shrouds
20 sets will be available
  7. abaddon - PAID and SHIPPED
  9. barney five - PAID and SHIPPED
  10. FokkerVF - PAID and SHIPPED
  11. ObscureReferenc - PAID and SHIPPED
  12. krithargus
  13. asoncsm101
  14. MooseF - PAID and SHIPPED
  15. Johnnyfl - PAID and SHIPPED
  16. Jim - PAID and SHIPPED
  17. JLinNY
  18. holto
  19. FullMetalJoe
  20. Available
Magwell Tabs
Milled from aluminum like the originals on the hero with bead blasted finish.
View attachment 1780284View attachment 1780285View attachment 1780286
GBP£22.00 per pair plus actual postage from UK. Tracked shipping to the US GBP£10.00
  • Designed to match from photos and reference first hand research at Bapty
  • Come with correct rivets (we recommend cutting the rivets off and gluing the tabs and rivets to the shrouds as regular rivet installation can put a lot of stress on the fiberglass and gel coats)
10 sets available
  1. DarthWilder
  2. DarthWilder
  3. userd1402
  4. Moosh89
  5. barney five
  6. barney five
  7. FokkerVF
  8. Johnnyfl
  9. Available
  10. Available
Coming Soon!
Slings
  1. Jim
  2. DarthWilder
  3. mugatu
  4. Available
  5. Available
  6. Available
  7. Available
  8. Available
  9. Available
  10. Available
Available Now!
Thompson Grip
10 Available:
  4. asoncsm101 - PAID and SHIPPED
  5. Hirohawa
  6. FokkerVF - PAID and SHIPPED
  7. Available
  8. Available
  9. Available
  10. Available
  7. 8 Hole - userd1402 - PAID and SHIPPED
Barrel Vent
  17. 10 Hole - asoncsm101 - PAID and SHIPPED
  20. 10 Hole - OCD is me - PAID and SHIPPED
Shoulder Stocks
Shrouds
  12. krithargus
  13. asoncsm101
  17. JLinNY
  18. holto
  19. FullMetalJoe
  20. Available
Magwell Tabs
10 sets available
  1. DarthWilder
  2. DarthWilder
  3. userd1402
  4. Moosh89
  5. barney five
  6. barney five
  7. FokkerVF
  8. Johnnyfl
  9. Available
  10. Available
Coming Soon!
Slings
  1. Jim
  2. DarthWilder
  3. mugatu
  4. Available
  5. Available
  6. Available
  7. Available
  8. Available
  9. Available
  10. Avail
Another photo of the production sample showing how thin uniform the fiberglass is. This is inside the top "handle".
Awesome Work. Please put me on the waiting list for the next available set of shrouds. Perhaps two...
All of the Magwell Tabs we currently have in hand are spoken for, if there happens to be interest beyond that we can start a wait list and see about making more.
Also some of our other parts are sold out, the shroud list is full though we cannot hold places in the list indefinitely. If you're interested in anything grab them now while you can! :)
I didn't see the magwell tabs post until now as I don't come here much these days, but I'd like a set please if you make more.
Also I'd like a barrel extension.
Thanks!
Harry
Have you added Harry!
I have updated the first post to include an interest list for the barrel extensions too, if I missed anyone please let me know!
Could you expand on what you mean by "cutting the rivets off"? Do you mean removing the mandrel somehow (can it just be pulled out?) or cutting it at the rivet body?
Harry
