Re: Echo Station 57, we're on our way....slowly
I think mike made some great points inherently the hulls
of the speeder are going to be weak it's just part of that shape
and design. I noticed once adding the canopy things strengthened
up, but even then I couldn't do it without the top hull being taped
down at the correct height first. I also noticed it was nearly impossible
to make the canopy separate and cut out all the view screens
and then get it sit up in the hull!!:angry Every time I cut the screens out
the canopy would weaken and change shape, so I had to build it up
on the hull and glue as I went.Then I came back and cut out the screens
as it was locked in place.
At that point if your going to sit it down you still have to tape the sides, abd yes the boxes will add some definite support as mike said, but i would still
suggest keeping it taped down!
This is the rear bulkhead and it's just a paper template for the part
that I cut out in 3mm styrene, once it's fitted the top hull is rock
solid and you can set it down on it's own weight!:thumbsup
Here it is in plastic ready to be glued in place.
