Davehenry
Member
Re: Spiderman web shooter: A collaborative project. Even more 3D Print Goodness!!!
I am trying to understand this. Could u show us more pics of the top and all sides. If u could that would be super.That's another project I'm working on that happened to be sitting on my bench. It's a Vu Meter and I just placed the part on top of it.
For the actual lighting, I just bought some 1.6mm LED with leads. That's about as small as you can get before going into surface mounted lighting. I bought them from here:
1.6mm LED
I got a pack of clear green and red for $6.00 shipped. Can't wait for them to get here so I can start on the electronics. :thumbsup
Also here's a small update regarding lighting:
Here you can get a better idea of the set up that I'm going to be going with. That glass tube inside the base is something called a reed switch. It activates whenever a strong magnetic field comes into proximity.
Now, the idea is that I drill a small hole in the cartridge and place the magnet inside; so now the cartridge will act as the switch and turn on the led lights when it's inserted. Neat eh?
