Re: Vibro axe again.
Damn, I still have no luck finding some resin blaster grille parts. Surely somebody must make them?
I won't mind getting accurate pipe thingy too, although I'm perfectly happy with the ones from Adamata
Honestly, I think it would be cheaper, and better in the long run, to just cut down the toy blaster grill. I had one of the orange ones setting around for years, and finally a few months back, I got axe fever and cut it, and shaped it for my vibro, but then I found out, that out of the two blasters I had, I cut up the wrong one.
So, I figured, if I was going to do something, might as well do it all the way, and I picked up a broken, vintage, toy blaster for next to nothing. There are a lot of little differences, inside, and out, between the vintage, and newer blasters. I would get vintage, if you can, the inside, is an easier, and safer mod to do, and the plastic, is easyer to work with, IMO. The Vintage acts a little more like resin, in that it's more sandable, and fillable, and I think it will take pant better. Plus, the newer one (at least the one I worked with) have blocky things on the inside, that I had to grind down, so the pipe would go through the part. The vintage one didn't have the blocks. (man I wish I had taken pics of the inside of them, before I modded them out. )
I really like Adamata's pipe assembly, and I really appreciate him including one with the most excellent cast resin soaker, I bout off him.
I just want to try to do something a little closer to the correct size for my more accurate axe. if I do my second axe, I'm totally using Adamata's pipe.
I walked around Lowes a few times looking for parts to do the pipe assembly, but every thing that I found was a little price for my taste. Like $7. or $8. a part, and there would be a few parts. And, wall that is not outrages, I think I could make it out of junk I have around the apartment. Well, at least that's what I'm going to try first, when I get time.
I really need the Screw thing for the side of the supermax too. I know TK409 makes a very nice one, but to be honest there a little pricey for my taste. (hey, he even said I might be better off making my own.
) So I have to give that a try too.
Oh, it's not in the pic, but I made the other round part that goes under the Yamaha part. I just found a pipe with the correct inside diameter, rolled out some sculpy, and used the pipe as a cookie cutter, and then I just backed the sculpy. A little sanding, and wah-lah, disky thing. (hey it doesn't have to be fancy, it goes on top of one part, and under another one.
