Loving the look of the jacket! Though I seem to miss the collar snap and the pocket zippers seem to be reversed as in, when the pockets are closed the zippers should be at the bottom. Apart from that I think it looks great!
Aaah I stand corrected! I didn't saw it was open!
About the collar snap's visibilty I always believed it was visible but I'm sure someone else here knows the jacket a lot better then I do and can give the answer!
That new one is looking much better. (EDIT: Snaps are visible like you have them on previous model. Easy fix.)
Is the color set? Can't see it in the pic so double check that the chest seam detail is present. (See pic)
Was wondering if the panels could go a little darker and less yellow? Otherwise I'm sure any of us can distress it to get it darker.
Looking real good. BTW- What size is that one?
OK, I thought this was being worked out as a standard size. How exactly is this going to work if the prototype is already being altered for a custom before it's all set? Normally the pattern is fixed at say a size 42 or 44 then you'd size it up/down and go custom after that. Confused as to how anyone can place an order without set specs to base off of.
The custom fit will be our measurements but fit the same way it fit Hugh, correct? I think that's what is confusing him. Say it hangs just above Hugh's belt, take someone's body measurements to fit where it hangs from THEIR belt. Right? Take Hugh's dimensions vs. the jacket dimensions, and add that formula to anyone's dimensions. That's how I see it anyway
Well, I believe the original was a size 44 for Hugh. So technically if we're trying to match the look for shapes and length you would create an identical size too get that all spot on. So I guess I would need to know what measurements you gave him for your size to see where this jacket lands. With patterns, taking in only the waist by a couple inches can alter the pattern drastically.
You're just slightly taller than me and I also have large shoulders but I run a 44-46 " chest. So if your length and shoulders match, the chest measurement change alone can throw a ton of things out of whack when altered. That's why it's usually best for a run of anything to do a 1:1 match 1st and then let the custom changes factor in afterwards. What we have here now appears to be a custom jacket to you that now everyone else will need to figure out how to adjust for their own size while trying to stay accurate to the look.
Can you provide the specs for the current one and also the size info you provided to him. That will help me judge what size this is closest to and what will be different and by how much.
Patterns are like dominoes. Change one thing and it affects the next and so on. I'm hoping this one's measurements aren't too far off a standard size.
